Steering Rack Replacement
petethepug
Michael
SoCal
Did the Detroit Axle rack too in an 09 Esky ESV. For $219.56 using a promo code and free shipping with a lifetime warranty as well as postage paid for the core, I couldn’t pass that up.
Knock on wood, it’s a great rack so far. Keeping my original rack for a rebuild at a rack shop so I will not be getting D/A lifetime warranty since I not returning it.
Dustin Jackson
Dustin Jackson
@blondie70 The steering rack comes with the inner tie rods already installed along with the boots, if that’s what you’re asking
blondie70
Yes...thanks Dustin. How do you grease the inner tie rods or even is it neccessary ? Talking about under the rubber boot ! Thanks
petethepug
Michael
SoCal
How many miles you have on that one? I don’t know if the one I used had a warranty
The truck is just coming up on 190k miles. The D/A rack has about 50 miles on it. Detroit axle says lifetime warranty on the racks. I only discovered it by peeling the warranty card off the box and reading the fine print.
bruizer
Good find on the Detroit axle. I was about to head to the junker hope for the best. Will be tackling that and new outers this weekend
lspann3525
Im going to install mine this weekend. I paid 30 bucks for the power steering cup seals from autozone and they had to be shipped to my home but later found other power steering seals on rockauto for $9. Im going to hold on to my OEM Rack as well. Just in case the new one starts to leak the lifetime warranty they promote sounds good but if they are rebuilding quality parts I shouldnt have a problem
lspann3525
by chance know the torque spec for steering shaft to rack bolt i will be using blue loctite
alpha_omega
Michigan
I went with the detriot axle rack and pinion it came with new outer tie rods but no o-rings or jam nut...How are yall securing the steering wheel from moving
I followed the TSB and used the pin that the dealership uses, along with the ole seatbelt trick just to be safe.
edit: I went with the Plews & Edlemann Rack and Pinion, their Pump, PS Lines/Hoses and they sent me a really nice reusable PS filter kit for free. I had one hang up with the PS Pump not having the second mounting bolt for the bracket. They corrected the issue right away and overnighted a whole new pump at no charge. Fantastic customer service and a family owned business who stands behind their products. Being from Michigan you would think I went with Detroit, but overall I liked the P&E gear a little better.
Towmaster
