Should I remove my rack? Opinions wanted.
LuSe4
Bleen Member
Michigan
In my slow quest to modify my Tahoe, I have considered removing the factory rack. I am looking for a good deal on an esky rack, but till then, what do you think about removing it? Does de-racking only look good on lowered trucks?
Here are some pics as it sits now. (From my phone, so quality isn't great)
Thanks for any input.
05Yukon23
Arkdelphia, AR
I think it looks good without it. I drove around without mine while they were drying and like it. The only thing that I HATED was the fact that you can see the studs the bolts go into and it looks like crap.
L
LuSe4
Bleen Member
Michigan
I think it looks good without it. I road around without mine while they were drying and like it. The only thing that I HATED was the fact that you can see the studs the bolts go into and it looks like crap.
Did you buy "set screws", or use screws with heads on them?
05Yukon23
Arkdelphia, AR
I just left the screws out. It wasn't too bad until I walked up on it or if I was parked somewhere that when walking back I was a little higher up.
mmeachem
Nice truck I luv the color but I think you should keep rack
Good luck
Sidepipes
SF Bay Area
I just took off the two cross bars. SF has one old parking garage with very low clearance, and now I can just squeak in with out rubbing. My high point now is 6' 2".
gdddup
NJ
take the rack off n see how you like it.
i took my roof rack off for like a month. i liked it at first but up close you can still see the top of the threaded insert. the best thing would to have the inserts removed, holes welded up smoothed and repainted. more work than i wanted to get into.
i ened up modding the yukon rack by painted the caps and polishing the rails.
bkboatnsleds
McHenry, IL
I say leave it... boot leg rack.. but end up with the esky rack - would look awesome on your truck!
Tahoewhat
Ballin' on a Budget
TX
take it off and buy my Escalade Roof Rack, why do a fake rack, when you can have the real one.
All though his roof rack does look cool.
DenaliAK
Colder than you
Alaska
Leave it.
Or take it off.
Don't do the Esky rack. They look tacky IMO.
My $.02
SOCWhiteOut
I like it without them but one thing i do recommend doing if u leave them off for good is getting like door trim or whatever and (if u cant find ur paint job color) paint it to match ur paint them applying a strip of the trim over all the studs, its makes it look 10x's better and there was a thread on this i saw one time that sparked me to do it so if i find it ill post a link here.
Buford bubba
