Last weekend I replaced my transfer case fluid. Done this many times on many 4x4's I have owned over the years. This time it's got me baffled, or I am just getting old and senile?
I cracked both the plugs loose.Then removed the drain plug. The old oil came out fast. When I removed the fill plug MORE oil came out of THAT hole! That freaked me out. Why the hell is it doing that??? Shouldn't it be coming out the bottom hole??
So I put the drain plug back in and started to fill it back up using a hand pump and hose. The book calls for 2 quarts. I pumped all 2 quarts in and still nothing came out of the fill hole, BUT when I removed the fill hose it must have been snug enough to block the damned hole so fluid started gushing the **** out.
So I am laying there on my back all ****** up and panicking with this brand new fluid running out all over the place and thinking should I let it keep doing that? Can it really be that over full if it is calling for 2 qts?? I mean I swear by the time I had to react I lost at least a half quart. I just jammed fill plug back in and snugged them up. Shit's got me a bit nervous....
