rocketman76
I installed a TBSS Belltech kit 2-3/4. Instead of replacing damaged Autoride struts with OEM parts, I replaced them with Bilstein HDs, 24-186926
(F4-BE5-E374-H1).
I then replaced the rears with Bilstein HDs, 24-186933 (F4-BE5-E375-H0).
I was hoping for a slightly lower front end, (installed spacer under rear springs) for 3 inch rear drop, but the rear sits lower than the back.
Could it be that I ordered the kit when I planned to use Autoride shocks and struts? Should I remove Belltech shock extenders and see how that looks?
(F4-BE5-E374-H1).
