reset steering angle sensor problem - SOLVED
persistent
i have completed a deep engine repair (failed piston rings), and i am struggling to get past the issues i'm having with the steering system. i had a major misalignment with my steering gear, fixed it, got the steering column lined up properly, adjusted the inner tie rod bolts to set the toe, and i continue to get several dtcs that relate to the steering angle sensor - U0415, U0428, U0422, C0710-4B, C0544-5A. the car drives fine for the most part despite these dtcs.
my best guess is that these various dtcs are all related to the steering angle sensor (sas for short) having some nonsensical value as a result of my steering alignment issues. i have 2 scan tools here - a cgsulit sc530 and a launch x431 crp919x - and both of them claim to support sas reset, but neither of them will reset it.
i'm looking for a scan tool that is confirmed to support sas reset for the 2015-2020 tahoe, or any other advice that helps me get past these sas-related dtcs and the associated disabling of stabilitrak, etc.
P
persistent
appreciate the reminder to rtfm. the service and repair manual i have suggests doing 2 things to address the C0710 code: first, use a scan tool to read the steering wheel angle and confirm it varies continuously over its full range (-550 to +550 deg), then perform the sas recentering procedure.
i'll start with trying to access the live angle data.
P
persistent
i cannot get steering angle sensor data from either of the 2 scan tools listed above nor hp tuners mpvi3.
am i right to say that the steering sensor needs to be aligned similar to the clock spring, meaning i may have to recenter it manually? i see videos about replacing steering sensors requiring alignment before install.
EDIT: after having a look at these videos, all the videos are for the prior generations of gm vehicles, i.e. 2014 and earlier. the 2015+ sensor appears to not have a pin/center setting, suggesting it would not be possible to get it out of alignment.
P
persistent
i grabbed a replacement sensor, part 13590209, from the local dealership, and i have confirmed that hp tuners mpvi3 can see live angle data from the replacement sensor, whereas it cannot see any live data from the installed sensor. the mpvi3 does not support sas reset or learn, and neither of the other 2 scan tools can see the live angle data or reset the sensor.
since properly replacing the sensor requires disconnecting the upper steering column, i quickly tested the part was working by unplugging the old sensor, disconnecting battery, plugging in new sensor, connecting battery, and then checking live data with mpvi3. i have an xtool d8s coming today, and if that cannot reset and learn for this sensor, i will cave and get a mdi2 + gds2.
do i also need tech2win to use mdi2 for bidirectional functions like sas reset? i'm not familiar with this software stack.
No, when you sign up for the GDS2 subscription, you get the ability to do bi-directional control. At least ours did when we worked on a Cadillac SRX with the 3-day subscription to GDS2.
P
persistent
after connecting the new sensor, i have noticed that the steering angle dtcs (c0710 and c0544) have gone from current to history, which i assume indicates they are no longer active. i will remove the upper steering column, install the new sensor and see how things go.
P
persistent
it ends up that attaching the new sensor did not clear the c0710 and c0544 codes.
i pulled the steering column, replaced the sensor, reinstalled the steering column, and then i was able to do a sas relearn successfully from my xtool d8s. the sas relearn cleared the c0710 and c0544 codes and caused the stabilitrak and steering error messages to stop appearing. for sake of documenting it for others, i will test my other 2 scan tools to see if they can also perform a sas relearn. afaict, the problem i was encountering before is that if the sensor isn't generating live data, it's an indication the sensor is damaged or failed and needs to be replaced _before_ a sas relearn will complete. none of the scan tools gave any indication of this being the case.
the removal and reinstall of the steering column was one of the more difficult and frustrating things i've done so far with repair work. it was very awkward, cramped, and a real pain to get the nuts reinstalled on the studs.
Tupapi
