Rangel
My 2008 yukon feels a little sloppy in the front end. With 85k I figure the bearings need some attention. When it goes over certain bumps or RR tracks It sounds a little clunky. Moog has a front end package with new inner and out tie rod, and lower ball joints for $265/319 depending on control arm material. And I've seen moog UCA with ball joints for around $100 each. What else should I look at sway bar end links? Wheel bearing are good. I've read that the intermediate steering shaft will help tighten up the steering too as the "rag joint" will wear. Any opinion on that?
It's my wife's daily driver, but when I drive it I can tell the truck not as tight as my 09 sierra with 45k on it.
