Reducing engine noise in cabin
ls1frc
Hello, does anyone have any suggestion on how to reduce engine noise coming through the dash/floor area? After I swapped my lifters for Morels, which are definitely noisier than stock, my headers amplify the valvetrain pretty hard into the cabin. It's getting to the point where I want to put the manifolds back on, but I figured before I did that, I'd try to reduce the noise somehow. I know the dynamat stuff seems to help, I am just not sure where to put it.
Would a hoodliner help?
https://www.amazon.com/Dynamat-11905-Hoodliner-Self-Adhesive-Deadener/dp/B00069QLVC
There's a pretty decent mat under the carpet on the firewall, but virtually nothing on the floorboards/floorpan aside from the jute pad and carpet. Line the firewall with as much as you can but pay extra attention to the floors. Use the stick-on sheets directly on the metal then a MLV (mass loaded vinyl) on top of that, then cover it with the factory jute pad and carpet. Stage 2 would be doing the doors, on the backside of the outer skin and on the inside shell.
L
ls1frc
Ok I will buy some dynamat and give it a shot.
I guess I pull the two front seats, pull some trim, and peel the carpet back? Any pictures/guides on how to do this?
BG1988
turn up the radio
Hybrid exhaust upgrade it's quiet :) sometime I have to check if the engine is still running
L
ls1frc
turn up the radio
Honestly, that's what I do lol. When DVD is playing for my kid or a/c is on don't really notice it. Windows down, don't notice either.
DRKN57
Sometimes the simple solutions are the best solutions. The A/C fan is so loud it drowns out most noise for me.
L
ls1frc
Yeah I got used to it, doesn't really bother me anymore. It's worth it now that i know I dropped the 0-60 by a full second.
DRKN57
Yup, that’ll do it.
BG1988
there is some oem engine bay sound dampening not sure of the part# though
go to a junk yard and swipe it off a hybrid from the firewall and hood it will quiet it by about 20-30%
TallHoe 96 OBS
