Rear lift gate glass hinge seperation?!
St. Louis
For the third time!! Yes!! The glass from the 2005 and 2006 SUVs will fit directly onto an older SUV! Lol even though on the older glass the top hinges are integrated in to the trim they are still shaped exactly identical to the newer ones and the newer ones will match up the tailgate hinges on the older trucks. Lol
You sure? Even if it's from an Esky?
[emoji1787]
Larryjb
You're starting to sound like me. I'm a high school teacher. (Sorry Tom!) :beer:
Larryjb
2nd esky hatch... does that mean they break too?
It seems like the center brake lamp is integrated with the hatch on the esky, whereas the Tahoe center lamp is in the roof frame. If so, does one just remove the center lamp for the Tahoe and plug the esky center lamp into the existing harness?
Okay, never mind. I just found a video that answers my questions.
adventurenali92
Big Bear Lake, ca
The first esky hatch I bought was a 2004 esky hatch. After a couple years on my truck the lift support hinges delaminates from the trim. The drivers side had a pretty huge gap. I was afraid if I kept opening it that the glass would shatter eventually as I’ve heard of it happening a couple times. Anyways I scored a really clean hatch off a 2002 escalade the first day it was made available at the junkyard in the high desert at the base of the mountain I live on and it had the tail light base still attached when I got there, though the light had already been grabbed. The third tail light base on the Escalade is glued with adhesive to the exterior portion of the glass, not part of the trim surround, then there are three screws that go through the glass and the base mount and screw into the underside of the tail light. Here you can see the three screw holes:
I took the 2002 hatch that I scored with intact lift support mounts, and used heavy grade JB weld all around the area where the lift support mount meets the trim, before mounting on the truck. It’s been on the truck since June and the lift support mounts have held up with the JB weld. No separation as of yet.
chevrol8t
chevrol8t
@chevrol8t
How is the repair holding up now that is been a year?
Sorry for the late reply. Well the passenger side is still holding strong. The driver side gave a little (I may not have put enough on.) I was going to attempt a repair this weekend but I'm chasing a front end vibration. Maybe Ujoints (hopfully). So I may have to tackle the repair another weekend.
Larryjb
Matthew, from what I hear, the 2005/6 hatch doesn't crack out.
You could buy some 3M 5200 marine adhesive sealant. That repair lasted about 2 years for me. I may not have added enough of the sealant overtop of the hinge. Also, they say if you run a heat gun directly over the freshly applied sealant, it will flow better into voids and make a better seal.
I'm just going to wait for a 2005/6 hatch to become available.
chevrol8t
chevrol8t
FYI. About two days ago I repaired the driver side rear glass hinge. Feels stronger now. Hopefully it should last. Driver side hinge is still holding strong from first repair.
Mtncrvr
And here you can see the tail light glued to the exterior of the glass over the trim surround piece and the lift support mount separating from the trim surround:
View attachment 258433 View attachment 258434 View attachment 258435
This is exactly the problem I’m having on my ‘03. I was thinking to Expoxy/JB weld it and use speed clamps while it dries (carefully that is). Thought maybe the replacement gas struts were too strong causing the separation but it seems to be a design flaw. Thanks for the write up !!
Matthew Jeschke
Sahuarita, Arizona
I'm still in need of repairing mine... I have a terrible habit of leaving things unfinished. I bought the 3M windshield glue. It's on my self ready to be done...
6point2lovelifers
