Rear leaf spring bracket 98’ Tahoe 2dr 4w/d
Vanagain
I’m in need of a rear leaf spring brackets for my 98’ Tahoe 2dr. 4w/d
I have tried #722-071 and they are all around wrong. The four bracket/frame bolt holes 2front to 2back holes are different heights apart. Any questions please ask.
Any help out there will be much appreciated
Thanks
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I looked this up at RA and the only other option is the RWD bracket. If you cannot find, you may have to customize the ones you have. It also calls for the same brackets on a year older and a year newer application.
Welcome to the forum from Oregon. Pics please.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
dizhai
