Rear door speakers not working
Jeremyhuskers
I have a 1999 tahoe. A year ago I replaced the rear door speakers and replaced the head unit. Everything worked. Today I noticed that the rear door speakers are not longer working. The cargo and front door speakers are working just fine. I checked the cigarette lighter fuse and it is still good. Does anyone have any ideas on what to do?
Marbor
Chicago, IL
any updates on this im having the same issue. Replaced speaker and still no sound. Is there an amp connected to these speakers? If so how do I bypass
bigdog9191999
sw michigan
double check the connections from the deck to the truck harness could be bad there also, but as suggested the amp could be going bad also. I will have to do some digging to find it, but if you search for amp bypass, you order a metra deck harness and repin it to basically make a loop that connects the wires bypassing the amp. I did this in my 02 burb and it worked great, make it better with an aftermarket deck and added sub ( as the sock sub was bad, and was not gonna be as much as I was wanting. )
mrtahoe42
I had this same problem when I installed a aftermarket radio I had to hook up the blue power antenna wire (blue) to the other amp wire (blue)on the harness
rludlam1
I had same problem but my amp wire was pink.
WITCH1975
