Rattling sound during acceleration
Tgaff08
Yo, I gotta 98 2 door LT with about 102K miles.
I am hearing a pretty nasty rattling sound coming from under the vehicle when I accelerate. It began as I was driving around town then went away. I later did some highway driving and noticed a bit of a shake around 75 mph so I stayed around 65 for good measure. It rattles all the time now (when accelerating), sometimes it goes away if I get it over 50 mph but then it usually starts shaking again.
When I put it in neutral and rev it everything sounds normal so there's no problem there. Is it the transmission dying?
retorq
Kingman AZ
My wheel bearings made a nasty rattle ... till I changed them. Sounded like marbles in a coffee can.
T
Tgaff08
Will the wheel bearings rattle when the vehicle is coasting?
fyremanpat
Fyremanpat
had a similar problem. thought it was the trans, turned out to be the rear end. spun a bearing on the lsd...one shop wanted to charge me well over a grand to replace everything, another charged me a couple of hundred to re-use everything and just fix the problem..couldnt be happier with a couple extra hundred bucks left over. dont wait to long though to fix it
retorq
Kingman AZ
Yes cause you are moving.
Like fyremanpat said don't wait to long what ever it is. I let my wheel bearings go to long and one welded itself to the spindle. That was a rather interesting fix ... LOL
T
Tgaff08
Tried to take apart the u joint and snapped 2 of the bolts in the process.
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Since you say while accelerating and shaking, I am leaning towards an engine issue. It might be 'preignition" or knocking. Try using 93 octane fuel, and if it goes away then its going to be that. Common causes are improper heat range plugs, overheating, timing issue etc. Any check engine codes?
T
Tgaff08
yes tis a 4wd
I pretty much confirmed its the u joint. Part of the lip is bent up pretty good (bad).
I got the 4 bolts off but the shaft wont budge. I only had time to shimmy one of the clips off. Do the rest of these need to come off before the shaft moves? Or am I just really weak?
retorq
Kingman AZ
Pics of what you are talking about??
Pics of you to confirm or deny weakness?? :p
PexoA78
