another day of ac work....
i decided to just charge the system for the lowest possible chiller water temp. which i can get down to about 31*. hood open, extra fan in front (only reason im allowing that is I plan on putting a pusher fan in front, already ordered) hood closed the psi jumps up (300ish psi) and starts to raise the ECT.
so i relieved some of the charge with the hood closed down till the pressure was back down to about 250psi, chiller temp was still about 38-40* and temp would stabilized - parked, hood down, no fan.
drove it around for a while with just chiller, then i turned down that water pump and turned on the cabin ac....took a few mins and it cooled fine with chiller pump around 30%.
soon as i get the other fan on it i should be able to put a little more charge into it and keep the ECT from climbing.
belt.... the k060520 belt goes on, and is on the loosest notch of the tensioner. i did have one come off on decel meaning it probably slammed the tensioner back to the no slack side and came off and it was brand new still kinda stiff. i have the same belt on it and so long as i come off WOT without just foot completely off pedal its stayed on. i ordered the next size shorter, k060516 if it looks to work good ill order a spare of two of it
/\ the lost belt was also the raised edge pulley with the old tensioner, so that may have also been part of the prob. since new tensioner and pulley, havent lost the belt
