Question about STARTING and Voltage Issue.
MATTHEW J PALUMBO
I have a 2009 LTZ Tahoe. Been having an issue that goes like this.
Sometimes vehicle starts just fine no issues, AC runs, ALL electronics are fine.
Sometimes vehicle starts and the voltage stays low, like right near 9 volts lows. When this happens, if I drive the vehicle, whatever causes a drain to the electrical system, AC, Electric fans, etc, the voltage will continue to drop and cause the "check charging system" message to scroll up and battery light to turn on.
IF, I see the voltage is low from start, I can shut the vehicle down and restart once or twice and it will go back to normal. It will run fine after this.
This all started after a dealership did my inspection. It came back with this voltage issue and my rear brakes were jacked as well. (I have not gone back to the dealership due to sheer frustration)
I HAVE, replaced the alternator, the battery and the electric fans (i thought at first the trigger was when the High speed fans turned on for the AC. Additionally I replace the fan control relay and the Fan High Speed relay.
Next steps are going to be checking the ground wires throughout, possibly changing the starter (maybe bad solenoid), and the Mega Fuse on the firewall.
I have verified that the voltage is right, when acting properly and is low when it reads low.
Any other suggestions?
MATTHEW J PALUMBO
MATTHEW J PALUMBO
Check your battery connections and clean them. Also could be an alternator going bad.
I replaced the alternator already, that was one of my initial thoughts.. I replaced without test the old one.. not a great move.. but it was a few minute job and a few bucks.
kbuskill
NE. FL.
These trucks have RVC (regulated voltage control). Trace your ground cable from the battery down to the RVC sensor, it is a ring that the ground cable passes through.
Unplug the RVC sensor and see if it fixes your issue. If it does buy a new RVC sensor or just leave it unplugged, no harm will be done.
The RVC was something GM did to try to improve fuel mileage by disabling the alternator when certain conditions are met.
when you get this low voltage thing going on where are you checking the voltage? try checking at the alternator output and then check it again at the battery.
GMT800 SUV/Trucks
Welcome to the forum from Oregon. Read this link: https://www.fixmyoldride.com/Chevro...e7e5cd24ed24635&at_ab=per-2&at_pos=3&at_tot=4
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
jeff2007 Yukon
