Passenger side rear upper shock bolt - HOW??!!
Darkstar72
I spent an hour messing with that pig and there is no combination of extensions, sockets, etc that I could get on that damn bolt with the rear a/c lines and that goddamn wire harness on the frame. I give up. It will be going into the shop hopefully next week. Any chance a dealership will actually just install the shocks I already bought? I did get genuine GM rear magneride shocks.
pull the right rear wheel off, remove the splash shield, attach a impact to the bolt and hit it a few times if it doesn't just come loose then stick a large flathead up in the backside and hold it a little, shouldn't be that hard the only thing I see that might be in the way is the wire harness which should just be held in a plastic clip on the top of the frame that you can pry up.
gtrslngrchris
It was extremely annoying to do mine almost a month ago. It reminded me of swapping shackles on truck beds and if I hadn't done that a bunch of times I'd probably have had a much harder time. You definitely have to do some finger/hand acrobatics or just have a tool that fits particularly well in there. I don't remember exactly how I did mine but I *think* it was my 1/2" ratchet with a swivel and then deep socket up on the inside and impact on the outside.
I can recommend the Duralast swivel adapters from AutoZone they've survived my impact guns for years now.
Darkstar72
Darkstar72
I did have the wheel liner removed and even went as far to take the heat shield off by the spare tire for more room to swing a ratchet around. The only way I can think of is either a 21 mm offset box end wrench on the inside and impact the nut off the outside. Possible to get a long thin ratchet up in the cavity up to the bolt and hope to lock it onto a socket with more acrobatics. It’s too hot down here to keep messing with it.
gtrslngrchris
I can agree with you about it being too hot for sure. You're not in Oklahoma are you? I would almost be tempted to help despite knowing how brutal it is outside especially the next few days.
it's pretty much been 110 here for like 10 days straight, finally dropped to 94 today because it's slightly overcast
Darkstar72
Darkstar72
Darkstar72
Darkstar72
Victory is mine! Had a good think on it yesterday after mowing the lawn. Finally got that sucker. Drivers side took all of like 15 minutes.
Got it done before the sun goes start scorching us here in South Carolina today. We have been over 95 for at least 2 weeks now. Summer is not my favorite.
PG01
Up here to the right
Good job brutha…. Sometimes ya just gotta step back for a few….
number9
Just did mine today and thought the same thing. Tried several different lengths of extensions & sockets until I found a length that would fit. Held the bolt with the ratchet and used a 7/8" box wrench to remove the nut. Done from laying on my back under the truck, didn't want to mess with pulling the fender liners if I didn't have to.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I took a 22MM wrench and made a stubby out of it to get in there through the top with the fender liner removed. Yeah the fingers take an ass kicking from the impact on the front of the bolt but it works.
5StarCustmSolutns
Almost Heaven, WV
At least 5-6 times in '24 I've had to make a tool to fix the tool that I needed to make the original repair I set out to accomplish!
Nice work!
Joeltz
Kobot
I just changed all of my dampers last week. The rears actually didn’t give me much trouble. I used a box end on the outside nut with a deep socket and 3 inch extension on the bolt from the inside. On the passenger side I went above the wiring harness but below the A/C lines. I didn’t full remove the liners but removed the torx screws and push pins that go into the frame and that was enough flex to access the outer nut without much fuss.
I use a deep 1/2” drive socket with ratchet on the inside, no extension. Don’t use the ratchet as a ratchet though- use a 1/2” drive impact on the outside to break it loose first, then switch to a box wrench and “ratchet” the wrench back and forth, which works the ratchet itself. Hold the ratchet in place. Works for me.
justinakay79
