ordered a cam for my tahoe
josueh95
josueh95
Get the HD2 Shift kit and servos and a good tune and you will be good for a while.
have a corvette servo on and a Black bear tune..will also add a Trans cooler soon and look into a shift kit
M Hankel
Vancouver, WA
Congrats on the cam install.
A trans cooler should help a lot. Excessive heat tends to kill automatics quickly and with the added power + looser converter will def add more heat.
Mike
Tahoebigdog03
Didn't some of these rigs come with a HD trans cooler stock? If so would you still have to install a aftermarket trans cooler.
Big Buttons
The SS Burb
South Texas
Yes they some with them. But, with all the extra heat he is going to be having a bigger one is needed.
candyman74
arnold, mo
amazon has the tru cool 40k for 136 shipped and if you go onto performance trucks theres a guy who sells a mounting kit for 75 with factory fittings and brackets. makes it a lot easier to install the cooler
---------- Post added at 08:35 PM ---------- Previous post was at 08:29 PM ----------
http://www.performancetrucks.net/fo...nstall-kit-brackets-fittings-hardware-508374/
---------- Post added at 08:38 PM ---------- Previous post was at 08:35 PM ----------
http://www.amazon.com/s/ref=nb_sb_s...ywords=tru cool 40k&sprefix=tru+cool+,aps,554
bottomline2000
Dallas, TX
will give them a call to see what they say but the pac 1218 are some great springs and now i just have to decide which 7.5 pushrods to go with!
You're gonna love that Camshaft i know i do. Our cams are almost identical. I went with 216/224 on a 551/ lift, Mine is made by vinci It's called "The Trucker CAM" i went with Lunati Voodoo Beehive Valve Springs and Comp Cam 7.4 pushrods as far as gaskets i would go with a LS-1 TIMING COVER GASKET SET.
You might want to consider changing out the Water Pump/Timing Chain/ if you have high mileage, since everything will be torn apart.
did either of you measure for your pushrods before ordering? Just wondering how you determined the proper length as neither seem to have used a pushrod checker..
bottomline2000
Dallas, TX
Nice. I got the pushrod checker so I'll go thru the motions just to see what number I get..7.4 most likely. I'm going with the Vinci trucker cam and stock lifters but just want to be sure.
Sent from my SAMSUNG-SM-G900A using Tapatalk
D Rollins
