ordered a cam for my tahoe
josueh95
hey guys so im finally going cammed..i went with a trick flow 216/220 .560 lift cam from summit racing
i will have to get some springs for it i hear the ls6 springs are kind of pushing the limits with this cam and that i should go with the pac 1218
i also have to get some pushrods and the gaskets i will need but i am stocked about getting this cam on
my current mods are CAI, LT headers, ORY-pipe, vette servo BB tune
josueh95
josueh95
will give them a call to see what they say but the pac 1218 are some great springs and now i just have to decide which 7.5 pushrods to go with!
Travieso
Boooooooost !
Los Skandeles, CA
You're gonna love that Camshaft i know i do. Our cams are almost identical. I went with 216/224 on a 551/ lift, Mine is made by vinci It's called "The Trucker CAM" i went with Lunati Voodoo Beehive Valve Springs and Comp Cam 7.4 pushrods as far as gaskets i would go with a LS-1 TIMING COVER GASKET SET.
You might want to consider changing out the Water Pump/Timing Chain/ if you have high mileage, since everything will be torn apart.
josueh95
josueh95
hey thanks bro! i ordered my PAC 1218 springs and brian tooley 7.4 rods so hopefully if there here by friday iwill get the swap done by saturday! im really exited to see what this cam will do with the other mods i got
M Hankel
Vancouver, WA
Good advice about the timing chain.
With the added valve lift/duration and higher spring pressures it puts added strain on the weak stock chain. You can upgrade to LS2 sprockets and chain for well under 100.00 and it's direct fit. Got mine for around 65.00 I think and they're very strong. Call up Scoggin Dickey Performance and they will set you up and their prices are great on the OEM stuff.
Mike
livingez_123
Sandy, OR
Make sure you install the oil pump correctly! you need to use 6 feeler gauges to set it up right before you tighten it down.
josueh95
josueh95
Mike
hmm i will look into that im right at 140k miles...thanks! getting the swap done this saturday...but i wont be doing it alone..a guy i know who builds turbos and knows alot about ls engines will be doing the swap
Travieso
Boooooooost !
Los Skandeles, CA
i swapped out timing chain and new water pump and i only had 77K when i did my swap, i regret not doing the oil pump, but i wanted peace and mind.
YukonXL04
The Riverboat
Arlington, TX
At 140k I would definitely swap the timing chain and the oil pump while you are there. The water pump can easily be done later though.
Tahoebigdog03
I've been listening to some 5.3 cammed on YouTube today and it's making me want to get one done really soon. I'm calling Comp Cams tomorrow to see what they can tell me.
josueh95
josueh95
Big Buttons
The SS Burb
South Texas
My cam totally woke up my truck. You will love it. Gonna want to get a stall so you can launch the crap out of it lol.
I have a .607/.614 219/227 112LSA cam with PRC dual springs and a 3200 stall, it's real fun to drive.
Travieso
Boooooooost !
Los Skandeles, CA
got the cam done yesterday guys! man does this thing pull harder now! love it! heres the first start up..smoke is jst from some oil on the headers
https://www.facebook.com/photo.php?v=772381959440025&set=o.124529014424579&type=2&theater
---------- Post added at 11:41 PM ---------- Previous post was at 11:40 PM ----------
your tahoe sounds awesome man!!
thanks bro, Your transmission aint gonna like it, i suggest you better start saving your money for a transmission
josueh95
josueh95
because of the cam? or jst the whole increase of hp with mods?
048tahoe
