Oil pressure sensor HELP!!!! - SOLVED
Spencer4991
Does this look to have a filter in it??? I have fished a hook in but can’t seem to grab anything and the new filter(not putting it in) doesn’t fit all the way down…. 2010 Chevy suburban
j91z28d1
were you able to get one out? I can't tell in that pic at all
Moderator
People's Republic of Colorado
I can't tell if there's a screen in there or not. Some people take a long deck screw or the like and stick it down there, turn it clockwise by hand and pull them out. YMMV
S
Spencer4991
I wasn’t able to get anything out….ill try a deck screw tomorrow, I’m dropping the pan anyways to change out the pick up tube gasket. I’m trying to cross everything off before replacing the pump.
Welcome to the Forum from NH.
Pics of the truck, please.
Not all of these motors had filter screens. @Doubeleive may be able to clarify which ones did not have a filter screen.
rdezs
I'm thinking that most likely looks like one. Should lift right out with like an o-ring pick tool
solli5pack
I'm still shocked some of you can change it with the manifold still in place.......
Los Angeles, CA
The valley cover looks like an LS2 cover. Is that a 6.0?
When I did the DOD delete I noticed the LS2 cover is shorter and thinner so a screen wont fit in there. The VLOM is thicker and taller to give the screen space
S
Spencer4991
All right, few days later update there wasn’t a filter in there put a new oil pressure sensor in went and got some engine. Flush ran that through the engine. Did an oil change still low pressure finally listen to what everybody has been saying about the O-ring on the pick up tube inside the pan and went ahead and changed it l…. That was exactly the problem now I’m getting 19-25 idle psi and 40-55psi driving
Buford bubba
