Cam like broke or just wore out? When it went did it damage more stuff when it took dump? 173k here. I want to afm delete and maybe a light cam... but not really in the plans this moment.
typically the oil tube pick up ring is the know problem with these but...
when I bought mine used from a gmc dealership I luckily had purchased a warranty I flew and picked it up in las vegas and drove it home 7 hours.
on the way home I noticed the oil pressure going all coocoo but it ran fine and didn't throw any codes or anything, so after I got it home a couple weeks later I took it to the local dealer to have them check it out. they initially said it was probably the sensor (not under warranty) and so I said well go ahead and check to be sure so they manually tested it with a gauge instead and had the same results so they said it must be the oil pump but they would have to order one and said I could come pick it up and drive it until the parts came in, so went and go it and said I was taking a trip about 400 miles each way and did they think it was ok to drive it, sure you can drive it.........
so I did and on the way there the pressure dropped once to 10psi and threw a code, so I reset it and kept going, then on the way back it did the same thing a couple times and I just said screw resetting it and drove it home.
when I took it back to the dealer to have the oil pump fixed/replaced or whatever they were going to do they said when they pulled the pan they found a chunk of metal stuck in the pump. they said the cam took a dump and it needs a new engine.
so in the end I had the warranty which covered a rebuilt motor and I kicked in the extra cost $1000 and optioned for a new crate motor instead.
