NORCAL SS Custom 2/3.5-4.5 for all 2wd 2015+ GM SUV
CMil527
Old Bridge, NJ
I haven't installed the kit yet. But now I'm curious as this is the first I've heard of there being any clearance issues or modifications being made. I was under the impression the Belltech spindles were a pretty "bolt-on" swap for the stock spindles.
+1... Tony can you confirm? I'm getting pretty close to ordering but don't wanna run into issue's during install and have to modify parts as my vehicle is a lease!
dbbd1
Sorry, just had to make sure that we all knew that there was no clearance problems and no cutting with 2wd.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
2wd or 4wd it works fine... done hundreds
CMoore711
So 2WD 4WD doesn't matter, there should be no requirement for any trimming or modifying ball joint bolts, control arms, etc. for any clearance issues with the front Belltech lowering spindles in this kit?
Tahoe14
Central Fl
Tony, glad to see you back posting as there has been a lot of questions lately about lifts.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I do mostly drops but can set up a monor lift also
Laurents10
