Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My 98 2dr tahoe’s oil pressure gauge reads zero and runs rough. I ’m assuming I need a new oil pump. Any recommendations on which oil pump to get or are they all the same?
gm oem which is delco or delphi. sealed power is very good too. in the meantime STOP RUNNING THE ENGINE. maybe pull the dizzy first and check the gearing and slot the oil pump shaft goes into.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
