New spot for spare tire.
AppocAlexx
Darth Appocalexx
Abilene TX
You could always look at the hitch mounted spare tire set up. Or if you're into custom fab work do a swing out off your rear bumper.
TURNz
TURNz
Redoing the exhaust sounds expensive. I think I'm going to look at mounting it inside. Also, my rims are apparently 17s from a newer Tahoe, with 33" tires. Will 33s even fit in the stock location? I recall seeing guys mention that a full size spare for larger than stock tires don't fit. But I don't know that this small increase over stock is enough to matter.
Sent from my SM-G935V using Tapatalk
TURNz
TURNz
It looks like just the right side would need redone. Though the winch looks suspect. 62953dbce0e4524f245b844c72c16bfd.jpgea89f2447ec9017391a192adfdb8c77a.jpg
TURNz
TURNz
Nahhh just a little surface rust you're good lol
I had the cable break on one in the middle of an intersection once while it was snowing after work. I was in dress shoes and fell twice retrieving it. That was fun.
Kbkiller
+1 on rerouting the exhaust. In my yukon xl I have the back seats out and there is a mounting point where the seat locks in to a cargo latch on the driver side tied down with a ratchet strap. It's a temp fix until I can fix my spare holder. My 05 sierra has 35x12.5 toyo mt's with matching spare that fits no problem.
05Single
afraid of the dark
New exhaust only axle back would only be around $75-$150 max. Not like a full cat back including muffler. After the axle is the easy part
BAMAUSAF
