New radiator is running colder
Multnomah Falls
This seems to imply that one can use this supplemental hose clamp to 'calibrate' the temperature at which one would prefer their truck to operate ... ?
It can let you know if any restriction of the hose makes a temp difference. How you use it after that is up to you.
Don't assume that the cluster gauge is linear or absolutely accurate -- it's designed to sit about in the middle of the gauge when the temp is normal, but the readings aren't absolute.
This is a well-documented issue with some aftermarket radiators. Lack of the restriction orifice in the fitting for the small return hose (to the surge tank) is common, and can cause over-cooling.
First of all, verify the coolant temp with a scanner reading live data.
Secondly, if it's running too cold, see this link and view the thread that's embedded in that post.
GRAYGEORGE
On the hose which runs from the top of the radiator to the overflow tank needs a nozzle in it to slow the flow. You can see the coolant flowing thru the tank. I used a 1/4 inch plastic cap off of a roll of copper tubing, drill a 3/32 hole in it. The flow to the overflow tank slowed down and temperature returned to normal.
Multnomah Falls
Same results as if you used a small hose clamp that you could adjust as needed to make the flow in the hose smaller.
D
David Kriss
Something lost in translation there my friend....
Butt injury!!
I would do that first. I searched my ass wound to find the problem and at least it was corrosion in the connector of the temperature sensor, which leads into a to low displayed temperature
see:
I finally had a chance to replace the temperature sensor. There was no corrosion on the connecters. I put in a new Duralast Gold sensor. The problem is solved. Either it was a coincidence that the old one failed at the same time or loosing all of the coolant over a minute or two took it out. Either way, it was a cheap and easy fix.
GMT 900 nut
