Need Sundown advice.
djtoothowd
arkansas
ok so back in Jan. or Feb. i began getting things together for my system install. and with all the rage i read about hear and on other websites about Sundown i figured i wouldnt be dissappointed with their product. now its 6 months after install and i wouldnt say im not impressed but i know i can get more out of setup. I'm not a guru yet and still have ALOT of learning to do so im coming to you guys.
I have the:
pioneer AVH4300dvd headunit
Sundown SAZ-1500
Sundown SA-15 D4
Stinger 0awg wire kit with 2nd Optima battery
Can't remember exact box dimensions but its tuned at 33hz. and i think around 7cf. Subs facing ceiling with port at bottom of box toward hatch.
i have yet to do the big 3 upgrade but will hopefully be doing it today.
I'm curious if i have the subs wired correct. The diagrahm i used.
http://a248.e.akamai.net/pix.crutch...subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
and im not to positive on my tuning. I have my:
-gain set at 38.72 volts with HU on flat and Sub-level at +6 on HU. HU LPF at 50hz.
-Bass Boost at 0.
-Subsonic at roughly 30.
-LPF at roughly 80.
-Phase at 0.
I know i can get more out of this but i know its something im doing wrong. considering building another box also.
any input?
Denali0229
FL
Its probably the box. If I remember correctly, that sub is 600 watts RMS. You are wired to 1 ohm so you're probably overpowering the sub by over double RMS. The more power you run, the smaller the box should be so 7 cubic feet is way too big. You should probably be in the 4-5 cubic foot range tuned in the low 30s. You should look into buying a set of plans for your box. They're like $30-40 and will be matched to your resonance and setup. It will make a big difference. Everything else looks fine. Maybe increase the LP filter to 63 or 80 hz. Get the big 3 done and check your voltage.
jdpber
GOLD MEMBER
The America
i agree the box is your issue. there are plans online and boxes are not difficult you just need to make all the custs square so there are no seam gaps.. but i think with a different box you woul get a better sound.. you can for the time beeing toss a few pillows CHEAP ones from walmart in the box and eat up some of that air space and make it sound better untill you get a smaller box..
djtoothowd
djtoothowd
arkansas
i had a local shop draw up the box dimensions for me for $50. it sounded pretty good when i first got it but then i started doing some research and decided to re-tune and now doesnt sound nothing like it did. I mainly want to change the way its ported. it only has one baffle from front to back. the guy who drew up my cut sheets said he made it to where i didnt need one goin up the back wall...if that makes since
ive found a few box ideas on the web that other people have drawn up for the same subs and for a tahoe that i may try. and as far as the cuts being square...i dont think i have any issue there. i used PLENTY of wood glue...lol the box is sterdy...i will try to find my plans and get u guys the dimensions when i get off this afternoon.
Denali0229
FL
How big is your port? You might get more output by going with a bigger port.
Sent from my PC36100 using Tapatalk 2
Knobz
Santa Cruz, CA
I'm running the same SA-15 @ 2ohms @ 1000watts RMS and it sounds super nice. I had a box designed for $65 from Pete at PWK Designs. Good stuff.
djtoothowd
djtoothowd
arkansas
ok. last nite i set my gain at 38.72 volts again (with speakers connected) and the knob is only maybe 1/4 or 3/8 of the ways up....that cant be right, can it? I'm not using bass boost at all because everywhere ive read, thats putting a death wish on your subs...i mean i expected the knob to be about 3/4 of the way up...or at least half. i can turn the gain knob all the way up and still not have much distortion...not sure about clipping...to be honest im not positive what clipping is..(dont judge me, still learning the "correct" way. ive always been the "tune by ear guy".)
Denali0229
FL
Your gain sounds right. What's the preout voltage of your headunit? Unless you have an oscope or a DD-1, you won't know if you're clipping. I'm pretty sure its your box.
groundscr8pr
flaccid member
scarborough maine
turn the lpf off on your deck.. if you cant.. turn it off on the amp and only use one of them. and set lpf for around 80.. if it sounded good then you re tuned it and it now sounds bad i highly doubt its the equipment!!
djtoothowd
djtoothowd
arkansas
when it sounds good i know for a fact that the gain is above the recommeded setting. i sounds good when i set it "properly" but it isnt as hard hitting as i want it. i can leave all settings at position as stated previously except when i turn the gain up i can get what i want. im sure its not the equipment...im happy with the equipment but in order to get it to sound the way i want i have to turn it up over the recommended gain settings. i just dont want to fry my $1000 worth of equipment, thats alot for me. lol
and i have no clue what db im hittin...no tools for sound..lol
groundscr8pr
flaccid member
scarborough maine
if the sub isnt bottoming or going into severe distortion with the gain set where you like it then go with it..jl does recommended gain setting on there sub amps.. i have never been able to achieve good output using there method, always end up turning the gain up. music is sourced so many diff ways today that you need to have some gain overlap to make up for it.
1LoudHoe
that box is gigantic for a sa15.. 7cubes... sa15s can take plenty of power. seen a sa8 on a ns1.. lol
but your box is big enough for 2 sa15s. i helped build one for 2 sa15 that was 7.15 cubes
sa15 with a 1500, id do 3-3.5cubes tuned between 32-35hz
Boone708
Illinois
You may also want to play with the orientation of your subs/port. I built a box for 3 12s, subs up/ports up. It sounded good but didnt hit hard enough. I laid it down for subs/ports facing the rear & the difference was incredible!
1LoudHoe
usually with suv's and tahoes especially, subs up port rear is USUALLY the best overall setup.
get on a TL and see what setup is louder on a meter.
perhaps you need to do a mdf roof, expanding foam in the roof and some damping to the roof and hole truck
Bigsteve04Ho
If you disconnect one sub does it sound better? Maybe they are out of phase. Just a possibility
CKendrick
