MY22 Tahoe Airbag Restraint system
KiraFNP25
Hi everyone, I have a 2022 Tahoe RST and my alert/light came on for the Safety Restraint system. I too cannot open my panoramic sunroof, no over head lighting, button doesn’t work for the hatch, etc. My biggest concern is the safety portion but really annoyed with not being able to open my sunroof. My garage door opener (which I just programmed the day before), still works. I’m a bit agitated, my husband and I spec this vehicle from factory and pay quite a penny for it! There shouldn’t be all these issues! Have anyone here see any resolutions?
WalleyeMikeIII
Sunny and Snowy Minnesota
That is for 2021’s, but possibly you have an issue w/ the connector. Take it to the dealer as a warranty issue.
msant
2023 Z71 Tahoe with SRS light and non operational sunroof and overhead console. Started at ~4000 miles.
Believe it or not GM fix for now is to press map light, cycle on and off - that resets airbag light and the sunroof and everything works. I asked dealer if GM was F-ing kidding about no solution....
Can't believe they aren't open about the simple (stupid and ridiculous) fix for now.
msant
I have the same issue on my 2022 Yukon AT4. It started 3 weeks after I purchased it brand new: "Service Safety Restraint System" message and airbag light came on, none of the overhead lights work, sunroof does not work, and any button on the overhead console is nonfunctional. It has been 2 months that I have been waiting on the part to get it fixed. So basically I have to just drive it around like that as they have no loaners. I contacted GM and opened a case with them about how it was a safety issue, but they didnt care. I've also read on several Facebook groups that other people are having the same issue and have yet to have their's fixed as well.
It is extremely frustrating.
Not sure if AT4 is the same as the Tahoe overhead console... but fix for my 2023 tahoe from GM is press map light turn on and off to resets SRS code and console works again. I have done it 3 times since getting truck back after 2 days.
beavis991
My 2023 High Country Tahoe has 1150 miles on it and it got the warning....they replaced the console and I noticed that my parking assist wouldn't turn on. The light wouldn't turn on it would only say parking assist turned off each time I pushed the button?!? I parked it and then went back out at lunch to see if it was turned off in the settings but it worked fine now but the safety restraint service message was back and nothing worked with the overhead console again.....So back to the dealer it went...luckily they provide loaners! But do you think the parking assist could have anything to do with this? Could it be tied into the airbag system somehow?
Eek001
Just an update on my AT4 since I never posted a resolution -- see previous posts on this thread. I had the whole overhead console replaced in March 2022 on my AT4 and all has been good since then. As for cycling the MAP lights prior to the replacement, I did try that and the dealer did as well, but unfortunately it did not work for my vehicle. I'm actually surprised to hear this is still happening in 2023s.
In regards to the park assist mentioned above, my park assist still worked during the 3 months my overhead console was non-functional, so I don't think they are related but I could be wrong.
Motocross338
I have a 2022 High Country Tahoe and the SRS warning light came on around two weeks ago (21,000 miles). Carried to the dealership yesterday, and the connector on a wiring harness under the driver's seat was bad. Luckily, they had the connector in stock so they cut and spliced the new one. So far, no issues and the warning light has not come on.
Full disclosure: the SRS warning light would come on multiple times on a < 10 minute drive and start before getting out the subdivision. Other times, it may have taken two plus hours to start dinging. Also, I never had any other issues with any other features such as the pano sunroof.
Laurents10
