My wheel is sticking out from the fender on one corner
VTburban
Vermont
So let's say I hypothetically put some new rims on my truck recently, but the passenger side front wheel is sticking out from the fender about one inch, while the rest of the wheels are tucked nicely into their housings...what would I suspect to be the culprit here? I hadn't noticed it on the old set of wheels, and I think I would have.
Also with this alleged set of new rims, which may be 22" with 285/45/22 tires, let's say I found them to be rubbing. I'm interested in learning about the 2x4 trick, or any other way to eliminate rubbing. It seems to be happening at the rear of the front wells, at about center of the wheel, which is just above the bottom of the well.
Additionally if I were to have these problems, I might also have noted a pronounced shake in the steering wheel when I hit 70mph on the highway. Doesn't happen all the time, just some of the time. Allegedly.
I don't have any photos yet, which is why I am alleging everything at this point, but any help would be appreciated.
KMeloney
Did you try the wheel in question in a different location? If it sticks out elsewhere, but no other wheel does, then it's the wheel. It sounds like the offset of one of your wheels is wrong.
I have the tires you mentioned, and I get some rubbing. But, it's only under specific, slow-speed circumstances. I don't think I'd get too concerned about it.
Modded
That Guy
One of your wheels has a lower offset than the others. That's why it sticks out.
The front one that sticks out probably rubs more as a result.
The shake could be due to lack of hub-centric rings being installed on the wheels or improper lug nut torque. On the extreme end, one or more of the wheels could be bent.
soulsea
Bar
One inch (25.5mm) would be a pretty significant difference if it's in the offset.
Have you tried temporarily rotating the front two wheels side to side to see if the problem follows the wheel or remains in place?
VTburban
VTburban
Vermont
Guys I haven't tried anything to date. I just got them on a day ago, and haven't had a moment to spare. I'm actually going away again in a couple days so it'll have to wait until I get back, so I'll try to tackle it then. It's pretty significant; I noticed it almost as soon as the truck was off the jacks.
---------- Post added at 08:14 PM ---------- Previous post was at 08:12 PM ----------
So Neo, should I take this back to the guys that put them on, or take it to a specific type of tech to get it looked at?
Modded
That Guy
I recommend taking them back and asking if all the wheels have the same offset. Alsd tell them to install hub rings and torque the wheels to 125 ft/Lbs. Stock calls for 145 but that is awfully tight. A high speed RoadForce balance may also help.
On a side not, to literally stick out an inch from the rest is a lot.
I'm hoping some type of spacer or lug pattern adapter was not installed on that front wheel to cause such a difference because that could be the source of your steering shake.
VTburban
VTburban
Vermont
Ok thanks, I'll get that done asap. Thanks to all for the input.
Donovan
RIO GRANDE VALLEY, TX
Sound like you have some issues dude. Here you go hope this helps.
Offset: wheel manufactures will sometimes build the same wheel in different offsets for a specific application. Example a set of 20 OE wheels off a 2007+ GM will be tucked inside the fender on a 2006 or older. In the aftermarket non- replica "market" manufactures want to make wheels to fit as many trucks as possible. Sometimes they make the same wheel with different offsets to fit different models that's require different offsets.
Balancing. Hubrings are good especially on aftermarket wheels that are dual bolt patterns. They center the wheel on the wheel on the hub. And reduce or eliminate vibration at low speeds usually 40-60mph.Vibration at 60mph and up is usually balancing. There is more than 1 way to balance a tire depending on the dimensions of the wheel. Road force is cool because it measures the run out of the wheel and tire separately and then tells you where to position the tire on the to get the best rolling assembly. This reduces the amount of weight it takes to balance the tires.
Torque. When you torque a wheel on a vehicle you are joining 2 pieces of precisely machined metal or aluminum in to one piece And then putting them through an extreme amount of stress. Studs, have a certain spring tension when torqued properly. A stud will actually stretch just a hair when the proper torque is applied. If it is under torqued the lugs can loosen up, if over torqued the stud can snap off. If a wheel is not installed properly you can warp the rotor or hub. This could also cause vibration. I would never recommend under torque. An engine builder would not change the torque of a head bolts because it seems high. He would rely on the manufactures specs. Not opinion.
InTruckDesign
SW CT,
I would pull the wheels and check the offset that is stamped on the wheels, you may have 2 different offsets... which if you have 2 with one offset and 2 with another offset then they were probably purchased that way...if 3 match and the fourth doesn't then you've been taken for a ride...get your $$ back asap.
VTburban
VTburban
Vermont
Ok, back from a long weekend. So I had the time to make a few calls, and here's where things stand...one wheel was not balanced well, so the vibes at 70mph are gone. According to my tire guy and Tony, who sold me my rims, Chevy intentionally makes the passenger side front wheel stick out slightly further than the others. I've been told I would not have noticed it with my stock rims, but with certain offsets it becomes apparent. Tony said he's got the same problem on his Esky. While I totally believe Tony, I haven't noticed it reported from anyone else who has dropped their ride and added larger rims, including the TBSS rims. Anyone care to chime in on this?
soulsea
Bar
I've never heard of such a thing.
Unless the offset on the rims is either different or defective there's no reason why two identical rims should stick out differently. Inconsistencies in drop height are normal, so far as I know, differences in how far the rims stick out, are not.
Plus an inch is a pretty significant amount ... personally I wouldn't roll like that, nor would I find it acceptable if I just put down for a new set of rims and tires as I'd expect those to fit perfectly.
hbr
Summerville, SC
I agree with Serge.......I've never heard of such a thing either and wouldn't accept it that way.
VTburban
VTburban
Vermont
I hadn't either. I called a couple of Chevy dealerships in the area and no one had ever heard of it. I plan on switching the wheels around tomorrow to see if there is any change. I'll take some pics too, so you guys can see exactly how pronounced it is.
Modded
That Guy
I have never heard of this either. I can also tell you right now that both my front tires stick out the same amount. Take some pics so we can see it better.
VTburban
VTburban
Vermont
Here's a crappy one I took last week in a hurry. I'll get more with the same vantage point and different angles.
soulsea
Bar
Holy shmolly!!!
Not even my old 24s with 20 offset stuck out that much.
No no no no, there's nothing good about this. :(
soulsea
Bar
This is with a wider 305/40/22 tire:
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
wow that camber is way off. Was it like that before the new rims? Didnt you lower it? I say get a alignmet, you may have damaged or bent suspension components or something wasnt tightened when it was lowered
Here is my 22 on 285 45 22.
picture.php
VTburban
VTburban
Vermont
I've got an appointment for an alignment this morning, we'll see what they say. One of the problems I'm having is no one around here is familiar with mods of any kind to these trucks, so I have to use regular mechanics and techs for everything I do, and some are kinda feeling their way through the dark I think. But yeah Ian, I used the 2" spindles up front, and I'm darn sure my old 20's and my 17" steelies weren't doing this.
yates ™
Resident Apple hater
Iowa
Have you pulled off the wheel to check the offset yet?
Drewphil
