My New Headunit and Backup Cam
jomulk56
Resident Lurker
IN
When I bought the Tahoe it had a crappy tablet style Power Acoustik unit installed that blocked the heater controls and drove me nuts. I ended up trading that for a set of factory 16's with good winter tires with a guy on CL. That solved my winter issue but left me with no tunes, so I began the search. I ended up going with a Jensen flip out, yes I know cheap but I'm on a budget and couldn't afford a double DIN like I wanted, and a back up cam. I've been working way too much and finally had 2 hours before work today so I called a buddy and we got it installed, minus the mic for the bluetooth. He soldered up the adapter to the headunit while I tore the hoe apart, ran the wires, and mounted the rear cam. Anyways enough talk....PICS!
Everything ready to go
iPod hooked up and working great
Hey look a brake light
Backup cam looking at a bunch of grass and trees
The cam - Absolute CAM-600
All in all it went fairly smooth. I still have to run the mic and need to go pic up an adaptor for the camera wire since it just BARELY reached the head unit. Not bad for 1 hour and 30 minutes.
NathanJax
Vacation Nathan
Jax, Fl
:rockit:
erock198
Schenectady, NY
backup camera is the best mod after the AUX ad the bluetooth. I used to back ito everything
blaqout
King Yukon
Indianapolis
Quick question, did you have to connect the reverse wire from the radio? If so, which wire did you tap into?
choodock
Waco, Texas
I just wired mine up yesterday on my 2004. I used the light green wire out of the black connector on the far right of the BCM.
jomulk56
jomulk56
Resident Lurker
IN
I just soldered a wire to the reverse light and ran it to the head unit.
briannorris
