my 2" 4" belltech is uneven
localceleb85
southern cali
i just lowered my 08 tahoe with a 2" 4" belltech spindles and springs, but is way to uneven. peeps are always asking if its airbagged, how can i bring the front down to match with out suffering to much ride quality, its bad enough im on 26's and ride already sucks
turboeclips
Austin, TX
do you have any pics? I have a 2/3 drop on mine and the rear did look a little lower, but when measured, it was actually even with the front.
Modded
That Guy
I think that for some reason your Bell tech adjustable front struts (if that's what you used) were not installed properly, you do know that to get 2" of drop with those struts you will need NO SPACERS AT ALL installed on the shock body.
Common mistake because some people forget that those struts work for -2" to +1" of height adjustment, which basically means that taking out four of six 1/2" spacers only equals -1" of drop.
NASTY GM
Nor Cal
2 choices
cut part of the stock coil (free)
purchase Belltech adjustable front struts (around $200)
NORCAL SS
SUV SUSPENSION GURU
the belltech drop struts are on back order until the end of the month which I would wait to do. But yes i have cut 3/4 loop on a few customers trucks that wanted it lower and it has turned out fine. pm me if you need anymore info.
NORCAL SS
SUV SUSPENSION GURU
good talkin to you on the phone yesterday i sent you the info on some other things in pm
WITCH1975
