DenaliReyes
So... 2005 Denali XL 6.O Vortec 211k miles
I have been searching and I might have a problem with my engine losing pressure through either rear main seal leak, plugged oil pick up tube, broken gasket or bad oil pump.
I bought this truck from texas at 207k miles. Drove it to michigan, the first season it went through was that damn polar vortex.
That shtuff jammed my radio and now the screen doesnt work. Also it froze some freeze lines, co.ing from Texas it didnt have much antifreeze.
Well all the antifreeze has been taken care of.
Its I added a bottle of bars leak stopper, it didnt do much, I stil see a little antifreeze on the freeze line by the valley pan.
I recently changed the intake manifold gasket, cleaned the heads where the filter would go. Removed the knock sensors, cleaned them, it was dirty, had no sealant so there was gunk in the front one. Cleaned that up. I eventually will need to replace them.
I have an oil catch can because I figure this would take care of the white smoke that was coming on during cold starts... it fixed it.
So back to the main issue I have.
When I speed up from 50 to 70+ after a while I'll hear ticking noise from the driver side valve covers.
I cleaned the and changed valve cover gaskets recently, the rockets look good and clean, no gunk shtuff like that.
I have not tackled the oil pick up tube, is it a big job?
Can I get to it with out removing the harmonic bal? Maybe through the oil pan? Well that's my next project, starting with the small jobs. Eventually I'll just replace the engine if the cost is similar to just getting another engine on it.
I have used 0w30 on it, the pressure drops quick. At 5w30, not as much. I'm going to drain and fill with 10w30 mobile 1 and add Lucas oil leak stopper.
Any other ideas I should try out before giving up and just getting an engine?
At what milage should I just give up and look for replacements.
I want this truck to last, it is in great shape, no rust compared to what I used to find here in detroit.
Thank you amigos for your help
