Mcgaughy's 16" drop spindles.
irishplague68
I have 17" steelies on my 03 tahoe, and im thinking about getting the Mcgaughy's drop spindles for 16" rims so I dont have to cut off my ball joint stud for clearance. Does anyone have experience with these spindles, or know if they would behave differently than the original Mcgaughy's spindles for 17" rims? any info would be greatly appreciated.
NORCAL SS
SUV SUSPENSION GURU
do the djm arms with belltech sp shocks. 460 shipped and you can adjust from 2-3 inches and 16s will work no issues and includes new balljoints and bushings. You also WILL NOT lose turning radius as you do with those spindles.
I
irishplague68
Thanks Tony, Ive been going back and fourth on which way to do it. I actually already have the DJM arms and the 3 inch drop for the rear with the relocating brackets and sway bar links and shock extenders, I guess I was just thinking about it not being level with a 3-3 drop but I forgot that I could adjust the t-bars up front, duh. How much would the front sp shocks be shipped?
NORCAL SS
SUV SUSPENSION GURU
130 shipped and yah you can crank them up to lift it up and should be almost level orrrrrr do my 5-6 inch rear kit and will ride better in rear then it does now
koomie98
