Lsa blower
It’s a bit of work to get them working on our engines, it’s not a bolt-on solution by any means. And that blower body is only a part of what you need. You’ll need a bunch of other stuff. There’s one or two guys here who have made them work but you need to do a lot of research and need to know what you’re doing. Also, if your 02 is drive by cable I believe it’s a no go, you need drive by wire.
cmc76
Supposed to be a good amount of power. From what everyone says the hassle is in sourcing all the pieces.
Cb2004mj
not impossible. basically a intake manifold swap and front accessory change or adding a lower pulley and idler. plus a little rerouting of vacuum lines and wires for some sensors. maybe some harness lengthening or adapters for sensors. will need drive by wire as mentioned. and obviously a tune to match. suggested mods to blower are solid isolator. they are known weak and factory even replaces them. can make 550 whp on a 4.8 and upwards of 750 on a 6.2l. its all low end power, hit it from a light and smoke tires if you don't hook type power. 550whp with a lsa feels like 850 from a turbo car. they are BA setups but does take some doing to fit into a vehicle its not meant for. isn't cheap anymore with blower cost going up but not exactly expensive either. plan on around $5k if you shop around. yes it can be done for less but I'm saying with the upgrades, good injectors so you can add power later, good cooler, upgraded pump, etc
C
Chris2144
Well that sucks. It was a nice dream though lol
C
Chris2144
Well that guy is selling a set of 899 heads and a short block with for 800 for everything
cmc76
I'd have to do some digging. But theres an outfit that sells an LSA kit. I can't imagine why you coudnt put a checklist together. It will be a long one.
That way as you compile it all you have what you need
Off Road Pedia
