Lowered Tahoe
Edwardnavalo
I have a 2003 Tahoe 2wd I just bought , according to previous owner it was lowered on the rear , and Tahoe rolls side to side on freeway really bad , any one have that problem before ?
LordWayback
Swaybar bushings are a known problem but it could be something else especially if it’s really bad I would go to a place like big brand tire and Atleast mine will give a free or cheap inspection you could be in for as little as sway bar bushings or all new rear suspension.
E
Edwardnavalo
Thank you , previous owner told me it was lowered 1 up front and 4 in the rear
As @LordWayback stated above, get it checked out by a local quality repair shop, just to see if there are any suspension-related issues (particularly bushings and links conditions) that exist that can be identified and repaired/replaced.
If everything checks out as OK, consider purchasing a set of Hellwig sway bars for your truck. They are pricey, but they will eliminate any and all body roll.
Many folks on this Forum have lowered their trucks, and they will chime in regarding handling characteristics changes after lowering the truck.
E
Edwardnavalo
Thanks I took it to a shop and was told that my sway bar needs to be parallel to the floor and mine at the moment is towards the floor
2nd part of your problem are those shocks. I had them on for maybe a week or 2 then tossed them in the garbage. They suck. Do you have ZW7 in your rpo codes?
E
Edwardnavalo
Yeah I do have the zw7 , what shocks did you go with ?
E
Edwardnavalo
The part number for these is 344045 , and when I look them up on autozone it gives me a different one . If it has shock extenders can I still use the Oem length shocks ?
I have Bilstein 4600. ZW7 comes with the Nivomat shocks, which are really firm, so the springs are a little soft. You can't use non Nivomat shocks with the Nivomat springs, if you do then you'll be experiencing the exact conditions you're having now. Same thing happened to me until I used lowering springs. It was really scary driving on the highway. It was like someone was pushing it side to side in the back.
E
Edwardnavalo
Ok so the bilstein 4600 would go good with the 4 inch lowering spring my Tahoe has in the rear ?
Getting shorter end links in the rear to level the bar would increase its effectiveness. How about the front? That's where the rear story lies when it comes to excessive sway. But, also with the rear, the springs could be too soft. When driving straight and you hit a bump, does the rear feel cushy?
E
Edwardnavalo
I appreciate it , I didn’t know any of this and just trying to get it to ride well on the highway
E
Edwardnavalo
Worked on my 3" drop. Make sure you use the drop brackets for the shocks.
I appreciate it , im going to look into those bilsteins . Did you use the shorter rear sway bar links as well ?
E
Edwardnavalo
The front doesn’t feel bad , the front is lowered an inch . In the rear it feels as if there is no shock , it makes sense now that tonyrodz explained it to me , how the shocks that are on it right now are no good , I’m going to get the bilsteins.
Moderator
People's Republic of Colorado
Check the front sway bar links and make sure they're in place and in good condition. Also the front jounce stops need to be contacting the lower control arms.
Lots of people make the mistake of changing the ZW7 suspension by replacing the Nivomat shocks (the G65 RPO code) with standard shocks, and without going to a firmer spring. Makes things really squirrely.
@Tonyrodz that driver's side parking brake cable should be under the sway bar (same as the passenger cable there). Like this:
E
Edwardnavalo
Ok I recently bought this Tahoe , it has a 4 inch drop in the rear , do you think as long as I get the correct shock it would get rid of the moving side to side when I’m at around 65 mph
BlacktopBandit76
