Load resistors or flasher unit for LED turn signals?
seven9st surfer
Milton, FL
Just installed my LED turn signals, and I've got the hyper blinking. Well, they hyper blink with the individual turn signals, but I get the normal flash rate with the emergency flashers. Is that normal?
Anyways, while looking into load resistors, I came across THIS. If I'm understanding this right, you just take out the stock relay, and replace it with this, and you don't need to add the load resistors. Will the one I linked work with my 03 Yukon? Thanks for any help.
chauncey0337
MLT, WA
Contact the seller to make sure that's the correct relay for your vehicle. And you only need one or the other, not both.
seven9st surfer
seven9st surfer
Milton, FL
Thanks for the advice. I was just about to email the seller when I came across a page selling replacement flasher relays. Looks like the stock relay is an EP-29, so I went ahead and pulled the trigger on the EP-29L LED relay. The pin layout looks the same, so hopefully it'll do the job. I'll post back in a few days when it comes in.
BillBlatt18
Latham, NY
I just bought an LED flasher module when I did mine rather than having to put resistors everywhere
chauncey0337
MLT, WA
Yeah, those resistors get hot too, so you gotta be careful where you place them. I'd go with the relay also.
BillBlatt18
Latham, NY
no I'm talking about the flasher module behind the dash that controls the flash rate. Behind the knee bolster
Sent from my Galaxy Nexus using Tapatalk
jasonp
