Little help for a new guy
Jesse k
I’m sure it’s been talked about many times but does anyone know of a place that sells the gear selector cable to linkage bushing for 2009 Tahoe 6 speed? Can’t seem to find one.
upload_2020-10-7_12-56-9-jpeg.259500
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Post the last 8 digits of your VIN and maybe @915_Tahoe can at least give you a part number.
I looked and if all you need is the lower cable that number is, I think, 20787608. I did not see just the bushing listed. Also says must replace upper cable at same time and that number, again I think, is 25995564.
Plus I looked up as a 4x4 and not just RWD since you did not say.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Bushing not serviced separate. Must also replace upper cable when replacing lower cable, due to design change.
GM#20787609 CABLE, A/TRNS RANGE SEL LVR (AT TRNS) (LWR CABLE) (WHEN REPL MUST REPL UPR CABLE 84868716) (MYC)
OR VietVet
Willamette Valley
Does that mean that the 8 digits indicate it is a RWD?
@915_Tahoe, of course I don't doubt the part number you gave but I was curious what part of the last 8 digits gives whether it is 2wd or 4wd?
When I look up parts for my friends at RA, I get a little confused with some of the terminology and even more confused looking up the parts at a GM parts warehouse.
TallHoe 96 OBS
