LIFTERS 08 Tahoe 5.3
George Owens
Good morning, I am getting ready to order parts to replace valve seals and lifters. There is nothing wrong with the lifters as of now but I figure I would do it just to prevent anything from happening. seeing as though I’m at 180k. I want to keep the AFM I do not want to do any delete. repeat I do not want to do any delete. I use a plug in device that keeps me in v8 all the time and it’s been treating me well My QUESTION is does the VLOM get replaced as well? Questions and comments are much appreciated
The VLOM should be replaced, you will get the improved, more reliable design, should you wish to let AFM run again or sell the car. And of course, it's not 14 years old!
Don't forget to also replace the lifter trays with GM OE only.
If you don't have the new valve cover, consider getting that for reduced oil consumption. @iamdub knows the number by heart for a 2008! LOL
The improved AFM parts are much more reliable than your original parts.
George Owens
George Owens
Now with this new VLOM is pretty much plug and play or is this something else I might have to replace like the Cam? Or anything? And I would definitely need that part number for the valve cover
George Owens
George Owens
Also I think I did add GM lifter trays to the list are they all the same because apparently on rockauto they got a front and back I added 2 of each
George Owens
George Owens
And also again, do anyone got the part number for GM lifters both afm and non afm?
VLOM is Plug and Play - 12571609
Rocker Cover - 12570427
Two Kinds, 12669184 and 12669185
Regular - 12648846
AFM - 12645725 or 12680871 (new number)
George Owens
George Owens
Ya
Regular - 12648846
Rockauto just can’t seem to find the lifters
George Owens
George Owens
Just put this order in, may have to look elsewhere for the lifters and vlom, valve cover etc
George Owens
George Owens
I would go Melling then, JB-2079 and JB-7011
May have to source other than Rock Auto, try Summit Racing and Jegs.
As much as I’d want to I saw a lot of bad reviews on parts that wasn’t GM, ac delco etc I’m really iffy on engine parts
Geotrash
Dave
Richmond, VA
I believe that Melling is the OEM manufacturer for GM lifters. I have one here on my desk beside a factory lifter from my 6.2 and they are indistinguishable inside and out.
I'm with you there except when we know who the OE supplier is. In this case, Melling is or was an OE supplier for many parts on these engines, oil pumps, cylinder liners, camshafts, lifters, etc.
George Owens
George Owens
I’ll guess I’ll consider them if I can’t find the ac delco, I just called a dealership and for 4 non and active afm they want $1k just for parts and to take the cake they not allowed to give me the part number on the phone crooks
George Owens
George Owens
Regular - 12648846
I forgot to ask you these lifters, they they updated ones? Cause when I ran them they kept saying won’t fit my vehicle
I don't think ACDelco actually manufactures anything. It's the name branded onto those products made by others that meet GM's standards, and they're sold as that ACDelco brand. There are three levels of GM standards: Original (formerly "OE"), Gold (formerly "Professional") and Silver (formerly "Advantage"). Only Original/OE are the same as what it left the factory with. The other two are quality and price levels of aftermarket variants. Based on everything else they made for GM/ACDelco, I don't see why Melling wouldn't have supplied them with lifters. Johnson does or did as well. Or maybe it's that Johnson makes the standard lifters and Melling makes the AFM lifters. Either way, I'm pretty sure you're just paying for a name out of those two.
Bentley95
