Lifted/Leveled 2021 - Postem Up
TexasTZ71
There is a post in this forum that explains how Hurst is doing it. Sounded like a previous gen 4” Ready lift with a custom made body lift. Someone in here called and got the details. Cutting of course as well. Likely large back spacers as well.
I ordered my 3.5” from RC and 275/65/20 for my stock rims, no backspacer. Installing in the 31st at 4WP. I almost went with the 6” but it was a pain in the ass. Couldn’t use the rims I wanted as I was going for large offset and no back spacer. Decided to fit in garage and use saved money for Corsa exhaust. 34’s ain’t much smaller than 35’s!!!
R32driver
Had a RC 2” in the front and 1” in the back installed today. Stock rims and offset with 285/65R20 Ridge Grapplers. ‘22 Yukon XL AT4 with no AR. Minor rubbing on the inside of the fender that I need to cut. What’s odd is that it sits around 1/2” higher in the front. May need to add another 1” in the back.
What are your front and rear measurements from center of wheel to fender lip? We have that kit on our XL SLT and it's 22.5" front and 23.25" rear. Or 38.25" front and 39" rear from the ground to fender lip on stock size tires. Either way it ended up 3/4" higher in the rear
Idolan
That was me who called Hurst. It's a Readylift kit for the front from 2020 model year with a rear spacer Hurst makes themselves. Pics of the cutting required to fit 35's in the original post
RIZE_UP
3.5" RC and frontier grill guard installed today . Not exactly what I want, But nothing else will fit 3.0L Diesels (supposedly). Tires next week...285/55R22 Geolanders M/T G003 fit
2022 High Country 3.0L Dirtymax
sanman28
What is it you are really wanting?
If possible, when you get those tires on….measure your clearance height for me?
RIZE_UP
8" -10" lift kit eventually. Spent 35 mins on phone with RC trying to get them to explain why the 6" lift according to them won't work on Diesels.
RIZE_UP
Aaaaannnnddddd….did they have a feasible reason?
No, just said It will not fit diesel models. Could not tell me which part would not fit. Its Rough Country.... not.exactly my choice of quality brands. It will work for now. 6"instuctions for suv has a truck in the instructions pictured..(page 11 picture 39, has a driveshaft to a rear straight axle),.so who know if they even know what they are doing.
R32driver
RC also says the 2/1 lift they have for suburbans/tahoes will not fit a yukon or a z71 but myself and others on here have found that to be incorrect as that kit indeed fits both yukons and z71 models
H1Chester
Now you just need a set of the PPV / Law Enforcement Tahoe wheels and everyone will be slowing down around you!!
Honestly, wouldn't mind a set of PPV wheels for my Summit White Z71...
RIZE_UP
Give us some side views when you get the tires.
Went wheels and tires, instead of just Tires. Not a fan of 22's
Yokahama Geolander G003 275/65 R20
Black Rhino Chase Wheel 20x8.5. Zero offest.
RC 3.5" Lift
2022 High Country 3.0L DirtyMax 4X4
Order Aug 31st 2021
Took Delivery Nov 2nd 2021
As of today 8,249 miles. AVG mpg 21.9
sanman28
RC 3.5" Lift
Order Aug 31st 2021
Sick ride.
fntiger
RC 3.5" Lift
Order Aug 31st 2021
Any cutting/trimming needed?
AllyNJ
