Well...
I am still doing some research and trying to find out more info on the CST lift.
Basically, I do not want to do any cutting or welding. I have read many threads about the Rough Country nnbs 3.5" lift and the Readylift SST 4" lift. I am leaning towards the RC lift but using bilstein 2" lift struts and a 1.5" spacer instead of the 3.5" spacer that comes in the kit. I will then piece together my own rear kit.
If I want it higher, I will do a body lift.
If I end up doing this, I will be using Rough Country's Diff drop brackets as a template and machining some more of them.
My goal is 285/55/22 terra grapplers.
---------- Post added at 05:56 AM ---------- Previous post was at 05:54 AM ----------
I don't mind cutting/trimming plastic, just not sure I want to cut or weld in order to drop the Diff for the 6" kits.
