Lift Kit 6"+
protonvx
I am seriously looking into lift kits. I would like to fit a 34" tire.
Are there any major differences between different brands?
P
protonvx
Ok, I have done quite a bit of research and I will not be doing a 6+ inch lift.
However, does anyone know if rear shocks from a 88-98 c/k 1500 will fit the mounts on the nnbs trucks?
P
protonvx
Well...
I am still doing some research and trying to find out more info on the CST lift.
Basically, I do not want to do any cutting or welding. I have read many threads about the Rough Country nnbs 3.5" lift and the Readylift SST 4" lift. I am leaning towards the RC lift but using bilstein 2" lift struts and a 1.5" spacer instead of the 3.5" spacer that comes in the kit. I will then piece together my own rear kit.
If I want it higher, I will do a body lift.
If I end up doing this, I will be using Rough Country's Diff drop brackets as a template and machining some more of them.
My goal is 285/55/22 terra grapplers.
---------- Post added at 05:56 AM ---------- Previous post was at 05:54 AM ----------
I don't mind cutting/trimming plastic, just not sure I want to cut or weld in order to drop the Diff for the 6" kits.
07warwagon
I have a set of Rancho 3" front knuckles available of you are interested.
P
protonvx
I might be, I was actually thinking about lifted spindles. PM me your best price.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Not really. It seems that even if I report every spam posted the admins or mods might ban them but the leave the posts up. That might be confusing or a turn off for others. Or maybe they just the search results. Who knows.
P
protonvx
Sorry, I was actually being sarcastic. I hate spammers.
brice715
