Lets play a game of what caused it....
rockola1971
rockola1971
Indiana (formerly IL)
And the winners are the ones that mentioned the TPS harness. The field mice had a field day. Replacement harness on order. It appears GM wires are tasty!
rockola1971
rockola1971
Burning alligator on the exhaust, which bites, in pain, in the fuel rail
how does a throttle body create lots of white smoke?
funky reading to ecm causing it to dump fuel? i'm at a loss....:shrug:
That and the ignition timing fiddled with by the PCM because of all the funkiness going on with the lack of correct control signal going to the throttle body motor control and incorrect feedback coming back telling the throttle blade position (its all completely lost and has no idea what the position is truly). Combine all that and you get some funky internal engine pressures blowing by the valves before they close along with the same pressure waves hitting the rings and head gaskets. My trouble may not be over. There could be some coolant getting burnt off in the combustion chamber too. I really dont need an excuse to put a fresh motor right now. Now summer time 2024 that would be a different story.
B-train
So....what to we (the winners) get for properly remote diagnosing your truck for you? Glad you came to our conclusions.....LOL
nonickatall
Germany
Did they legalize pot in Germany or did you just not know that there are no alligators in Indiana?
Yes, our government is actually planning on legalizing pot right now.
Since this government is by far the worst that post-war Germany has ever had, many say: They are doing this so that people can tolerate this government's policies better.
I, on the other hand, don't need pot, I have my truck and this forum. How could pot increase my well-being?:love62:
B-train
100% agree. It's the same here. Give the people just enough options/ "freedoms" to think we aren't indentured servants to the few on top. Keep them drunk enough, high enough, or ignorant enough, to prevent them from upsetting the status quo they have created.
nonickatall
Germany
I suspect that an intelligent sentence is true and affects all societies, especially those in western countries at the moment
Bad time make strong men.
Strong men make good times.
Good times make weak men.
Weak man make bad times.
That describe perfect the time after the second world war and the now world..
And i our case:
Strong man make good trucks
Good trucks keep man strong....
:thumbsup:
A resistance against these disposable electric cars made of plastic, where they want to make people believe that they are good for the environment.
Zoni
The subject: 2005 Yukon Denali...for those that dont know....that means factory 6.0 and AWD.
Short background: Yukon has been sitting in drive for an extended period of time.
Symptoms: Hard to start, Blowing major white smoke, Reduced Engine Power on the DIC, wont get to normal idle speed, idles erratically.
I suspected bad gas so I threw in some octane booster, 4 gals of new 87 octane and some HEET. Didnt fix anything.
Ill take all guesses as to the cause of this mess until 10/26/23 1700 EST before I post pic of the cause.
Ill give you 3 clues. (1) Its not a bad battery (2) There are no fuel leaks (3) I dont live in the City.
I’m with swathdiver
nonickatall
Germany
Well well... this thread is out of 'control'.... :893karatesmiley-thu
My input : The answer is : The vehicle should be at a quality auto shop. Then rent a Prius to drive to the bank....
You know that a Prius is a betrayal of the truck?
:cool:
Your truck will react by spontaneously corroding all ground points.
:oops:
dizhai
