Byoung1330
I just soldered white LEDs in my cluster. They made my cluster look blue. Did my auto hvac control also an it looks white like I wanted. Why does my cluster look blue. Because of the overlay or what?
What year? If it's a 03-06, the bluish tint can be removed if you CAREFULLY shave the back of the gauge cluster overlay with a very sharp razor blade. I have done about 4-5 clusters like that and they came out great. I also damaged one overlay in the process. So I can not stress enough that you have to be careful when shaving it.
I scraped too much/cut too deep. It wasn't COMPLETELY useless, a few lines on the tach were missing and there was basically a white "hole" in that spot. It was definitely a very obvious visual flaw, but not totally unusable. But being that this was for a customer, I had to replace the overlay. At least it was a stock 1500 overlay, so I quickly (and thankfully CHEAPLY) grabbed one at my local U-PULL-IT yard to replace it with. That was only the second one I ever did, so I quickly learned my lesson. I haven't damaged one since. Well, not enough damage that it was visible from the front of the cluster anyway. LolOh, it's the back of the overlay.... Duh. What do you mean 'damaged' was it rendered useless?
