LED Hyper-flash
TogaPC
Austin, TX
I'm shopping for LED's for my corners and side marker lights. I'm looking at V-LEDs.com. I know that we need load resisters to eliminate the hyper-flash but they offer 2 different ones and a replacement flasher as well. What is the best way to handle this. Not real shot up about the resisters because they get very hot and I don't want to catch my truck on fire. The electronic flashers look like a better idea but I don't know which one to get. Has anyone dealt with this? I could use some experienced advice.
Here is the link For the flashers I'm looking at.
Flashers at V-LEDs.com
Thanks for your help.
---------- Post added at 10:03 PM ---------- Previous post was at 08:28 PM ----------
http://www.v-leds.com/BlinkerWarning-Fix/Electronic-Flashers/GM-ELECTRONIC-LED-FLASHER-p5189343.html
http://www.v-leds.com/Exterior-LED/...Amber-LED/2-V-LEDS-AMBER-194-13-p8194231.html
http://www.v-leds.com/Exterior-LED/Turn-Signal-LED/Amber-LED/V-LEDS-AMBER-60-M-SMT-p4835729.html
90% sure this is what I need
Z-56 Hoe
What do I do????
Houston
I was hoping you where Going to say I just did this cuz this is one of my next mods.
TogaPC
TogaPC
Austin, TX
After more research I think my 03 has the 10 pin BCM instead of a simple relay. I did find a forum that shows how to mod this unit. I'm going to verify this tomorrow but I'm not going to mod it till I get a replacement unit just in case I screw up. I'll let you know
Here is the article I was looking at.
How'd you do? I really couldn't see a difference in the arc that was filed.
nharkey85
Alabama
Same. Can't tell how much was removed. I'm sure those with better electrical backgrounds could possibly make a few measurements across that loop and tell us what size resistor to solder in its place
vsaravia
