knock sensor code
jfpty5
The check engine light came on a couple weeks ago on my yukon xl. it goes off sometimes, but late comes back on. I took it to autozone to read the code and they said it was both knock sensors not communicating. Has anyone else had this issue? What should I check before removing the manifold to replace the sensors? I have a 2003 yukon xl 5.3 flex fuel. Thanks.
slocaddy
sarasota fl
You can check their Harness plug on the drivers side of intake. I just replaced mine about a month ago. Its a good idea to replace the knock sensor harness also.
Volant1
Volant guy
Upland, CA
the knock sensors are just like the fuel pumps on the tahoe's sooner or later they will go bad. You will need 2 knock sensors, the harness and head gaskets
slocaddy
sarasota fl
he meant intake gaskets, wich even though they are supposed to be re-useable it is better to replace.
dang i type slow
J
jfpty5
Thanks everyone for the info. How can you tell if the intake gasket is the updated one?
Buford bubba
