Is there such thing as too low?
992dr
Eastern N.C.
Little update… I’ll be moving from the state with the #1 worst roads in America to the state with the 5th best so I mighttttt try tucking some 28’s since I’d be able to run rubber bands without severe anxiety every time I leave the house
Heck yeah buddy
Where are you moving? Eastern NC :)
Dont forget to remove your turn signal stalk.. You wont need it there.. Either that or put it on, and super glue it.. Right is best!
I see WAY more signals being used here than in Louisiana. The lane change signal there is to aggressively swerve at you.
Doug118
Doug118
I’m just going to keep updating this as I find new things that bottom out front lower control arms. The rear of the arms now contacts the frame. Parked, there’s about 1 finger width between the arm and top of the mount
Doug118
Doug118
"Truck put you through"?
I'm pretty sure that truck didn't cut and lower itself.
Everything suspension wise has been great aside from the rear sway bar end link snapping
It’s the engine dying, rear windows working when they want, going through steering racks at an alarming rate, changing the rear main seal to only have it start leaking from the same area a few days later, etc etc
Marky Dissod
Despite all the nonsense this truck puts me through
Everything suspension wise has been great, aside from the rear sway bar end link snapping ...
Would it be accurate to add
to 'everything suspension wise'?
Or would going through steering racks at an alarming rate have nothing to do with getting low?
Doug118
Doug118
Would it be accurate to addto 'everything suspension wise'?
Nope both racks going bad had nothing to do with the suspension. First replacement one started leaking at the hose and the 10mm bolt stripped. Second one leaks from the seal where the steering shaft goes. I’m going to mark that one down as bad luck due to me being cheap and not wanting to spend $500+ on a new rack and lines
Mine has a very small leak where the LH inner tie rod goes into the body. It's not enough to drip and a new OE rack is pricey if available. I considered resealing it myself if a kit was available. I've heard these things are difficult to refurbish, or maybe just the seal replacement part is, so refurb'ed units often leak.
Geotrash
Dave
Richmond, VA
I installed a reman rack from Rock Auto in my '07 last year and so far, so good.
My 2007 enjoyed leaking, also. I replaced the pan gasket twice, rear main twice, front seal once and then gave up and just let it do it's thing after that. Figured if it wanted to leak that bad then have at it. I got tired of fighting it. The other GMT900's I've had didn't have the issue so no idea what was up with that rig LOL
brice715
