Intermittent parasitic draw
high mileage
Guys, I have a draw that happens randomly. Sometimes if I leave the truck parked it'll drain the battery in 2-4 days, other times it'll be fine for a week or more.
New alternator and charge cable, replaced the agm battery twice. I've now done a full parasitic draw test and the only circuit that had mV was the info circuit, which only had 1.8mV.
Am I screwed? What's next here?
Moderator
People's Republic of Colorado
Confirm for us that the mV reading was across the fuse test points.
Depending on fuse size, has that reading been converted to A (or mA) using the appropriate Power Probe Fuse Voltage Drop chart? (Estimated draw varies by fuse size and amp rating.)
H
high mileage
Voltage drop across fuse test points. That way you never interrupt the ground on the battery. 1.8mV=.0018v
Moderator
Voltage isn't current; that there is voltage drop indicates that there is current flowing in that circuit. But the voltage drop needs to be converted to current, so use the linked chart for the fuse type and size on that circuit and calculate the estimated current draw. We haven't been told the fuse type or its amp rating.
For example, if that's a 10A Mini Fuse with a voltage drop of 1.8 mV, there could be 1/4 A or so flowing:
To confirm the actual full draw when asleep, I would recommend connecting an ammeter inline in the negative cable where it connects to the battery. Then let everything fall asleep and see what the actual full system draw is. Maybe then pull the fuse in question to see if the draw drops accordingly. Monitor it for a while to see if anything is intermittently waking. Shoot for 25 mA or, ideally, less than that. 10 or 15 mA is a great number.
If there is anything aftermarket like an alarm system, radio, AFM disabler, etc., those are suspect. But you may need to look at wiring diagrams to see what's on that particular circuit.
H
high mileage
It's a 10a mini fuse. The problem is I can't catch this idiotic draw, it happens randomly. I think what I'll do is to wait til it dies again then test with an inline ammeter while it's dead. It does have an afm disabler- should I disconnect that in the meantime?
Moderator
Are you saying that the 1.8v drop on the INFO fuse isn't always there? I think I misunderstood from your initial post.
If it IS always there when the vehicle is asleep, that's enough draw to affect a battery. Maybe not overnight but within a day or two of sitting. I'd probably benchmark/document it by installing an ammeter now and seeing what the reading is. If it's consistent and repeatable, then while monitoring the ammeter I'd consider removing the AFM disabler to see how it affects the draw.
I don't see an "INFO" fuse in the online fusebox diagrams, unless I missed it -- where is it?
mikez71
On my '12 tahoe, the INFO fuse is #22 on the left I/P fuseblock (LBEC).
H
high mileage
Fuse 22 on the in car fusebox. And it's 1.8mV not colts. Within spec but it's the only draw I been able to find.
Moderator
Right, I mis-typed that, my bad. But 250 mA is not an insignificant draw -- how is that "within spec" when the vehicle is (or should be) asleep?
Probably not an issue, but every fusebox drawing I've looked at shows the inside fuse #22 to be for the DIC. I'm not saying that "INFO" is wrong but maybe I'm not looking at the right vehicle. (2010 Yukon Denali) Maybe it's just semantics, where GM labeled the truck different from the owner's manual.
H
high mileage
What's on that circuit anyway? Does the obd connector run through that? And yes you are correct, I was thinking mV not mA, it is excessive. INFO is how it's labelled in the fuse box itself, sorry. I'm unplugging the afm disabler and going to retest once the truck sleeps.
Mbarindelli
