I'm tuned for 91 but it runs way better on 87?
Physh1
Ok, I got a tune from you guys a few months back...03 Tahoe w 5.3
Optimized for 91, efan pin activated, cai, cat-back, reduced TM, etc...
I have been running 91 in it & things have been fine. My friend borrowed my truck & filled the truck up with 19 gallons of 87 (not knowing it needed 91). I get in the truck today & the thing hauls ass was more than I have ever felt.
So I have a tune for 91 but with a tank full of 87 it runs better & has more power. What's going on?
Cameron
thehoe92
fo sho
The916
just recently I noticed the same thing
I was VERY surprised when I put 87 in and one day started the hoe up and it was haulin ass
Brandon X
Michigan
So if im tuned for 91 I can still put in 87 and won't get spark knock?
blueflamed03
Oklahoma
you can put 87 in it, but the computer may pull timing to keep the knock sensors from going off....less timing/less power
Colorado Hoe II
Lower Octane fuel will burn with more power than a higher octane fuel. Higher Octane fuel will have less pre-ignition in a higher compression situation.
JennaBear
Resident Ninja
San Diego, CA
Cameron
With a traditional tune we have to make assumptions based on modifications. Those assumptions are not always perfect, but apply to most. Colder weather may also be playing a factor.
Physh1
Physh1
So if I did the cable tune deal we could fine tune my setup? I've been eying the AutoCal...
Cameron
Physh1
Physh1
Sounds good...I'll keep running 87 since it runs better until I can pick up an AutoCal.
Thanks!
Bwaldron
