We are looking for a used 2010-2014 Yukon XL. We would be open to Suburban if we could reach our towing power needed. We need it to be able to pull around 7,000 lbs. What I am running into is that I can find no easy way to determine pulling power. For example, if I'm looking at a 2011 Yukon XL, I know if it's a 6.2L Denali with a 3.42 axle, it can pull 7800-7900 lb (2wd vs awd). But what if it's not a Denali series but it has a trailering package? What can that pull? In this trailering guide (https://letstowthat.com/wp-content/uploads/2020/09/2011-GMC-Trailering-Guide.pdf), there are three options under a Yukon XL 4wd 5.3L, and only the third option can pull 8000 lbs, but it doesn't say if that's with a trailering package or what the difference is between that option and the above two options.
I found this website, but again, it doesn't delineate if something has a trailering package (https://www.autopadre.com/towing-capacity/gmc-yukon-xl)
And is there a difference between a tow package and a trailering package? And what if something is advertised as having a trailering package but they also say the rear axle is only 3.08? I read on one of the forums here that a trailering package should have a 3.42 rear axle.
Thank you in advance for any clarity you can give on this topic!
