how do you unplug side mirrors?
WhoDatPanic
im taking off side mirrors to paint and i understand that you pull off the triangle flap on the door and then unscrew the three nut bolts but how do you unplug the wire harness i cant find a plug ?? to unplug ?? plz help!!! its a 2003 tahoe.
WhoDatPanic
WhoDatPanic
can you just pop off that center part on the front or will it break and stuff ?
Badluck
SE WI
Can't say for sure cause I haven't removed mine yet. Sorry
Dylan
Houston, Tx
You will have to pull your door panel off to take it off. The wire is run down behind the door panel and held on by two push in clips taped to the wire. It plugs into your switches. Not hard at all to do.
mfinta
