Help with RPM Fluxuation
Shane71
I have a 2004 Z71 Chevy Tahoe with 115K miles. I recently had the transmission rebuilt. There really has never been major issues but I recently moved to the Washington, DC area. Now when it is cold (especially in the morning) I am hearing a whooshing sound and my RPM's go up then immediately fall back. I am not sure what it could be. I had someone tell me it could be a sticking valve. Any help would be appreciated.
S
Shane71
No check engine light. Again it only happens when its cold.
M3PO
Mid West/Cow Town USA
Sorry, I could have been more clear on my answer. What I was saying was: I think this might be normal, I had 02 Z71 with the belt driven fan before my 06 with an electric fan. The belt driven fan kicks on when first started/cold, I am not sure why, but they do. So it might be normal, have someone else start it cold, while you look at/listen to the fan, JUST KEEP YOUR HANDS AWAY!
91RS
GA
Clean the throttle body. The transmission place disconnected the battery to remove the transmission so now the PCM doesn't remember the dirty throttle's leanred position.
jaykel
x2 on cleaning out the throttle body...will def help
nick1126
what about the idle air control valve
Someone suggested the idle air control valve which I have not tried.
Thanks
Ron
[email protected]
91RS
GA
You don't have an idle air control.
jsmith14
My RPM was also fluctuating, i changed MAP, TPS and all, in the end it was actually the oxygen sensor that needed to be replaced. I visit my repair shop on Washington that tip on the problem. Changing O2 sensor fixed everything. you can look for some other Washington auto repair on your location that near you.
Big Jim
