Help locating build codes?
Cut Wagon
Senior Member
South La.
2019 Suburban Z71 5.3. My research says there is a sticker in glove box that tells me what paint code and rear gear etc. I can not find it. ‍♂️
Any help appreciated.
Cut Wagon
Cut Wagon
Senior Member
South La.
I did find this on driver door jam.
Blackcar
Scan the OR on label shown in your post with your phone will show you build codes.
If I remember right, the paint code is contained in the VIN. Whenever I purchase touchup paint, the dealer only askes me for my VIN to obtain the correct paint.
Cut Wagon
Cut Wagon
Senior Member
South La.
I got them from dealer. They just printed them out for me. Thanks for the help.
Blackcar
I scanned from your picture in post #2 and this is what came up.
1GNSKHKC5KR328626,2019,CK15906,04,19,06,WTDK8S, AG2 AN3 ARL AXP AYQ CF5 CJ4 C6H DD8 DL3 EF7 FE9 FHO GAZ GU6 G80 H0K IO6 I19 JD9 KG4 L83 MAH MYC NP5 NTB RBX RCV RUF TC2 UDD UQA U2K V8D WMK XCQ X88 Z71 Z82 1LT 4DP 6ZK 7ZK 8X2 9X2,8624,,,,
OK. I was not totally correct in stating that the paint code is contained in the VUN. However, the GM dealer can use your VIN to get access to the paint code.
While your car's VIN (Vehicle Identification Number) won't directly reveal the paint code, it is a crucial tool for finding it. You can use the VIN to identify your car's make, model, and year, which are necessary for locating the paint code on the vehicle itself or through online resources. Contacting your dealership with the VIN is often the easiest way to obtain the paint code.
scottd
