sunrisor
'03 Yukon XL 4WD
I am finally getting around to some much needed suspension attention. I am thinking of a modest 2.5" lift. I've seen lift kits that appear to have lift/level...which I don't want (not into the 'squat' look)
I've read a bunch of threads in this section and I think I've come up with a list:
T-bar keys
rear coil spacers
Longer springs?
longer shocks...? extenders?
longer bump stops...?
longer sway bar end links, front? ...rear?
Wheels will be 16", so as not to add the expense of a brake system upgrade.
Offset...don't want the wheels sticking out beyond the fender (or as little as possible).
This is still a daily driver, so ride quality needs to be an close to normal as I can get.
Any suppliers suggestions too, would be appreciated. I know Summit, Jegs, etc. but maybe there is someone else out there...
I saw a lot of different vehicles in this section, so I am sure I will get lots of great advice...
It's fast-approaching the 200k miles mark, so here is a loaded question: Should I replace the T-bars will I am at it?
Thanks for any and all ideas.
T-bar keys
rear coil spacers
Longer springs?
