Good grease gun?
99-02nut
Alex_M
What type of grease you use also has an effect on how much it leaks. I notice more sweat from red grease vs a thick moly lithium grease for example. This will also vary some brand of brand.
Y'all with your fancy grease guns are wild. I just go grab the cheapie pistol grip jobber from Rural King.
Alex_M
I use red anywhere I expect to see water - slip yokes are a good example. Moly lithium most other places such as ball joints, wheel bearings, etc. Cheap grease anywhere frequently serviced, anywhere I apply by hand such as when used for an anti-corrosive, to lube seals as an assembly aid, etc. At the end of the day, any grease is better than no fresh grease.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
My Alemite guns are 30+ years old and always work. They sweat and drip a little if stored too hot such as back of truck with shell in summer. I have a bucket with funnel,cartridges, and different tips for 3 guns.
I have to agree that Alemite makes quality products and customer service is exceptional.
randeez
south florida
:shrug:
grabbed one of these a couple weeks back, mostly because i had some needle zerks that require one hand pushing on it, cant pump with other single hand. have only used it with needle tip but so far so good. a little tip leakage
Hodmjstone
